Old-Biscuit
Sep 28, 2014Explorer III
YES....converter is failing.
Contact Randy at Best Converters. He will help you get proper replacement. LINK
Water pressure regulator......
Don't know if you have one built in. It would be just after city water connection.
Your camco reg is probably bad.
Should be easy to locate when you replace the broken city water assembly. That spring is part of the internal check valve which closes when using on-board pump otherwise water would flow out of connection and no water pressure inside rig. (pump also has one so city water doesn't back flow thru pump into fresh water tank)
About Fifth Wheel Group
