Paul_Clancy
Oct 09, 2014Explorer II
rhagfo wrote:Paul Clancy wrote:
It's Darco fabric. Mine was repaired by a dealer tech using uhmw poly strips (same as what the bar is made of) sealed to the slide bottom with Sikaflex and countersunk screws. Now the slide slides on Uhmw poly against Uhmw poly. It is a known issue across many brands that use the Darco and plastic bar design.
Where can one get the poly strips?
Order a sheet on line plastics international.com or professional plastics.com and then cut into strips. I believe a table saw was what the tech used. 1/8 thick sheet.
About Fifth Wheel Group
