Dayle1 wrote:
A 180 degree U-turn at full lock will cause cab to fiver contact, but few situations ever require full lock for the entire maneuver.
Dayle is correct. And not too many think of, or know that. A tight 180 U-Turn will cause 90 Degrees or more. It is even a bit more of a problem if the U-Turn is "off camber" at any point during the turn.
And we think that will never happen. But it can happen more often than we think. As in, when we need to pull out of a campsite in the wrong direction (due to trees or some other obstacle) and we need to pull a U-turn to go in the right direction. There are campgrounds like that. One that I remember is in Asheville, NC. And it is off camber, to boot. And you can't always just back out, either.
So as long as you know that you can try to avoid those situations.
And for those that say you should never get to 90 degrees because of suspension stress. I agree that you should not on a dry paved surface. Not so much of a concern if on sand, gravel, or soft ground.
For those that need to do that to back into their driveway, it is better if you can spread kitty litter, or sand, or even spray with water, where your tires are turning. This help to de-stress your suspension.
