laknox wrote:
azjeffh wrote:
My Maxxis 15" LREs lasted ~24 months before experiencing sidewall separation. Had to replace all 4 which were covered under warranty at Discount. Couldn't replace them with Maxxis which is another entirely different story. My trailer was only putting ~1975 lbs on each tire.
Run a TPMS and always checked for proper inflation, so that was not the issue.
While I will not bad mouth them due to the success reported on this forum, one should be aware that not everyone is a happy customer.
You needed tires =today= and it would take DT 24-48 hours to get them in; right? Same thing happened to me, which is why I ended up with the Carlisle RH's.
Lyle
Exactly Lyle. We were headed up the Beeline just past the Bush Hwy turnoff when my TPMS sounded. By the time I pulled over I had already lost 20 PSI. Decided to head back to Fountain Hills and right after I turned around another alarm sounded. Had to unplug the TPMS as I didn't have a spare. Got back to Fountain Hills with 21 PSI in that tire. All I could get in LRE was Tow Master :(
