GoPackGo's avatar
GoPackGo
Maxxis M8008 Tires Update
There is always discussion about tire problems on our 5th wheels so I wanted to post an update on my situation.
My 14,000 pound Bighorn came with LR-E 16" Towmax ST tires. It was exactly one year old when the first one blew (approx 5000 miles) so I replaced all 4 with the same size Maxxis tires.
I full time. I just stopped in Florida to hide for the winter after traveling for the last 6 months. The Maxxis tires have been on the fiver for about 16 months now and have about 9,200 miles on them. They look fine and I have experienced absolutely no problems with them.
I keep them inflated to 80 pounds and I travel at about 60 mph.
They have gone across Arizona and Southern California when the outside temps were over 100 degrees. I was in California for 2 1/2 months this past summer and it seemed like it was 100 degrees everywhere I went. Went across eastern Montana and the Badlands of South Dakota. It was HOT. So I think they got a pretty good test. I do know that the measure of an ST tire is more time based as opposed to miles traveled.
I know that Chinese made ST tires have a (mostly deserved) bad reputation, especially on heavier rigs, and I agree with that for the most part. But Maxxis tires are made in Thailand and seem to be better made.
I am not trying to re-ignite the LT vs ST tires debate. But there can be more then one solution to a problem. I am simply providing an update on the real-life non-second-hand solution I chose so that others are better informed. I will report back in one year.
Tim
  • Over 15,000 miles and 3 seasons on my Maxxis 8008 tires. I've also towed through the Southwest with temps well over 100 degrees.
  • Mine were made in Thailand.
    You're right, I should have differentiated between the two 'Chinas'.
    Tim
  • GPG - Good report - No debate necessary!
    Maxxis have always been quality tires.
    Maxxis (Cheng Shin Rubber Co.) is the 9th largest tire mfgr worldwide
    (old stats - ranking may gone up), producing tires for numerous applications.
    Clarification for Maxxis -
    Maxxis (Cheng Shin Rubber) is based in Taiwan - which is the Republic of China, with mfg facilities in:
    Taiwan (The Republic of China - "ROC") , Vietnam, Thailand, and Mainland China (Communist China - The Peoples Republic of China - "PRC").
    So mfg code will indicate the location where the tires where actually manufactured which may be one of the "China/s" or Thailand as you indicated.
    Cheng Shin has two huge mfg facilities in the PRC - as do other mfgrs, such as Michelin.
    The point is - The (mainland - PRC) Chinese are very capable of mfg tires to and for the specs of the buyer or company.
    There are company owned mfg facilities (eg: Maxxis & Michelin), and "generic" tire manufacturing facilities - for whatever name you -the buyer- want on the tires.
    Some want tires to meet minimal specs required for an ST tire, some want better.
    The reputation of an ST tire *brand* either stands up to the "real world" test, as yours did, or frequently (as other users experiences indicate) does not.
    Roll on!..:B
  • No problem what so ever with the Maxxis 8008's that were on our trailer either.. 6 Seasons, many many miles of trouble free service.
    I'm still a believer.
