JIMNLIN wrote:
The ST235/85/16, G-rated, Hartland tires (Gladiator clones) on our 5r have an "N" speed rating (87 MPH). Both the "ST" designator and the "N" speed rating are clearly imprinted on the sidewall.
The load G all steel ply or poly carcass tires are designated as commercial class ST tires and have little in common with a ST C/D/E poly carcass tire that has been so problematic in the past.
As others have mentioned some of the ST C/D/E are now speed rated above 65 mpg which may or may not determine better reliability or increased miles of service that can match a LT or the ST G commercial class tires.
Lets all hope they will.
I figure if I have an ST tire that's got an M or N speed rating, and I only drive 65, or less, that tire =should= last longer. What I'm hoping with my Carlisles, anyway. :-)
Lyle
