dustinlExplorerJan 11, 2020melting plugin the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
ItsyRVExplorerJan 11, 2020Are you using the same outlet all the time when this occurred or were you at different locations?Is it just one prong of the plug and is it always the same prong?
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???power cord plug melting7 pin plug amperage rating?Melted plug prong - would you use it?NEW, 30a plug starting to melt
