dustinlExplorerJan 11, 2020melting plugin the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
Old-BiscuitExplorer IIIJan 12, 2020WOW......three times melted plugProblem is NOT at the power pedestal it is in your power cord OR Main Power PanelNeed to go thru the wire connections in Main Panel and TIGHTEN them UPMight even find 'evidence' of overheating at connectionsHot wire to Main CB (Black)Ground wire to terminal strip (Green)NEUTRAL wire connedction (which is most likely loose) (White)
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???power cord plug melting7 pin plug amperage rating?Melted plug prong - would you use it?NEW, 30a plug starting to melt
