dustinlExplorerJan 11, 2020melting plugin the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
ksg5000Explorer IIJan 12, 2020Also - when you replace the plug are you making sure you cut back the wire so that you eliminate any of the damaged/brittle wire?
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???power cord plug melting7 pin plug amperage rating?Melted plug prong - would you use it?NEW, 30a plug starting to melt
