dustinl
Jan 11, 2020Explorer
melting plug
in the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
MNRon wrote:
Question for those wiser than me: If plug is melting (I assume he means one of the electrodes in the plug) that is evidence of too much heat at that point. That heat is caused by current and resistance, right?
IF the electrode has a solid connection into the socket why would a loose connection downstream cause that contact point to overheat? A short downstream would trip a breaker before current got crazy. A loose connection could cause lots of current spikes, potentially too short to trip a breaker, but I would expect the arcing (and associated heating/melting) to be at the point of the loose connection. If the plug electrode were solidly connected to the receptacle I wouldn’t think it would be a point of excessive heating.
With all that said, a plug connection will have some resistance but I would expect that to be much smaller than the resistance of the downstream intermittent connection. So again that is where I would expect arcing and melting.
Long way to say I think that if he’s having melting of his plug electrode, I would be looking for reasons it wasn’t making a solid connection and result in arcing there, not be looking first for downstream issues.
What am I missing?
