dustinlExplorerJan 11, 2020melting plugin the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
philhExplorer IIIJan 19, 2020What about smart plug cord and connectors? I know it won't fix the campground pedestal issue, but might help downstream?Here's a link to a source.Also, I've used a liquid connector "lubricant" in low voltage stuff, might it help with 120?
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???power cord plug melting7 pin plug amperage rating?Melted plug prong - would you use it?NEW, 30a plug starting to melt
