Dayle1
Nov 29, 2014Explorer II
Chevyman2006 wrote:
I want to be able to park with the driver's side as close to the inside wall as possible to hopefully park my truck beside camper. Just want to make sure I'll have enough true clearance at the sides.
18 ft wide is probably too narrow for both the TC and fiver. Inside clearance is probably less than 18 ft. So you have less than 24 inches clearance total split between each sidewall clearance plus clearance between the two RVs. I assume you would have to off-load the TC first, then back the fiver in keeping it perfectly straight to the building.
I have 17 ft just for the fiver and can open slides on both sides and still walk completely around the fiver.
About Fifth Wheel Group
