Hunter4593
Jun 17, 2013Explorer
Me Again wrote:
6 XPS Ribs at 3042 each provide for 18252 lbs of capacity on the axles. What is the GAWR?
The Bridgestone Duravis R250's or M895's are cheaper and as good as the Ribs.
Do you have at least 33" center to center on the axles for LT235/85R16's, if not look at 245/75R16's. With three axles G614 might be an overkill, and they are VERY expensive.
You are wise to dump the ST's!
Chris
GVWR is 18000. Will check Center to Center measurement today. I do know that space between tires is tight so may have to look at the 245/75/16.
About Fifth Wheel Group
