Me_Again
Jun 17, 2013Explorer III
So dry hitch weight is 2383, so load range E LT should be able to handle any load you put in it. The forest River Inc web site does not list GAWR.
If you hop over to the TH section, I think you will find that you are on the right track! You will also fine similar tire threads with problem after problem with cheap OEM ST tires.
Chris
Chris
About Fifth Wheel Group
