Me_Again
Jun 18, 2013Explorer III
FastEagle wrote:Hunter4593 wrote:Me Again wrote:
6 XPS Ribs at 3042 each provide for 18252 lbs of capacity on the axles. What is the GAWR?
The Bridgestone Duravis R250's or M895's are cheaper and as good as the Ribs.
Do you have at least 33" center to center on the axles for LT235/85R16's, if not look at 245/75R16's. With three axles G614 might be an overkill, and they are VERY expensive.
You are wise to dump the ST's!
Chris
GVWR is 18000. Will check Center to Center measurement today. I do know that space between tires is tight so may have to look at the 245/75/16.
One of the new twists I’ve recently encountered with light truck tires is a warranty provision disallowing coverage for LT tires used in misapplications.
Here is a link to the Michelin Standard Limited Warranty.
Click here
If you call or eMail Michelin of North America and give them the tire information off your trailer’s certification label I’m sure they will not recommend the XPS Rib to replace those tires.
There are other options in 16” sizes and many more in the 17.5” sizes. Many of the 17.5” tires are medium duty truck tires designed for low profile trailer service and will have higher speed ratings than the ST tires.
FastEagle
When are you going to hang up your crusade to keep people on cheap ST tires. A lot of us see right through what you are doing! Market market market!
Does this go hand and hand with when you said a few years ago that the government was going to ban LT tires on trailers.
I just leads one to think you are a paid shill!
Despite everything you say, BFG/Michelin is warrantying a failed Commercial TA that replaced Marathon ST on my friend Cardinal and paying for the trailer damage. And it was outside the window for recalled TA's. AND this happen about three months ago, so it fails in your recent window.
How about a little real world experience and not your internet hype just for once. Why would someone hate LT tires the way you do, and really hate the best in the XPS RIB. Do they cut into sales of cheap tires????? You always say Michelin HQ is just a short distances from your house. Why don't you go down and cut a deal with them to promote a good product all over the web?
Chris
About Fifth Wheel Group
