thefishingal's avatar
thefishingal
Mildew odor bathroom
Uggg I have a mildew odor in my bathroom and not sure why? I looked in cabinet and its dry. Inside shower stall has odor too. I have wiped everything down. Not sure where it's coming from. Anyone have any ideas?
I think it's going to make me nuts lol
  • I checked for leaks underside and didn't find any. Saw the cheater vent and changed that. No smell this morning.
    Thank you all for your help.
    God bless
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Bad air admittance valve, AKA "cheater vent", maybe. Rule this one out. Easy to replace; about $10.00 at Home Depot
  • Look from under the flooring to see if anything has leaked. Drains on showers have a nut to pull the drain down for sealing. Seals have been known to leak and I have seen some nuts come loose.
  • look in your basemant at the bathroom floor around the toilet or shower drain for stained or wet wood
  • 1st place to check is on the top of camper for a roof leak.
    could be leaking down the walls.
  • Has it been a while since using RV shower, so maybe P-trap is dry, allowing odor from tank?
    Jerry
