tk85
Jun 06, 2020Explorer
missing shore line
Good afternoon, I am new to the forum so please bear with me. I just bought a 1985 Elkhart Traveler 5th wheel. It has pass through several hands. My question is about the main power box it seem that s...
KD4UPL wrote:
The wires from the converter would not hook to the main breaker. Are you sure it's just a converter or did a previous owner install an inverter/charger with a transfer switch?
The shore cord hooks to the main breaker unless you also have a transfer switch for use of an onboard generator or an inverter.
The wires you describe, since there are a black and a red, would normally indicate a 240v/120v circuit. That is highly unusual for a converter. I strongly suspect it's an inverter/charger. In that case, your shore cord probably connects to it and the wire you have, being the inverter/charger's output, would hook to your main breaker.
