caysea7254ExplorerJul 17, 2016Modified sine wave power inverter ?We have an older 3000 watt modified sine wave power inverter. Problem is my curling iron will turn on but does not heat up at all. Please I know some of you are saying don't use the iron!! Don't have ...Show More
time2rollNomadJul 17, 2016Yes SW will run the curling iron. I only recommend SW for this very reason, everything works as designed.
Related ContentInverter Bad?Inverter installNo power on outside GFCI outletDecent inexpensive modified sine wave inverter3500w power inverter
