Thanks everybody for the replies. But according to GD you cannot run all 3 at the same time on the 395. This is really worrisome to me, because of the the issues I went through in my current trailer. Which it takes 2 AC's to keep it cool in the heat of the day. That's what has led me to look for feedback from actual users of their products.
arhayes wrote:
We have a GD 380TH which is the same size as the 385. I also can run all 3 AC's on 50 amps. The insulation is adequate in the living area and bedroom, but because of the large windows in the garage and the back ramp, it tends to stay a little warmer. If I was going to spend time in hot climates and use the garage area for living space, I'd probably put the reflective insulation on the windows to reduce some of the heat. With that said, we are in 90 degree days right now in AZ and we are comfortable.
Can you please define what temp. is comfortable for you? I am a day sleeper that likes it as cold as possible. Thanks
