sc1camping wrote:
I have a GD Momentum and run all 3 ACs at the same time. If all 3 were running and you added additional load by turning on the microwave or something automatic such as hot water heater, fridge, battery charger it is possible the load management system could shut off one or more ACs.
Most of these issue can be avoided by running fridge and water heater on gas only in very hot weather.
You will need all 3 ACs running hard in the South when temps go 90 plus with high humidity. This is only in late afternoon with direct sunlight.
X2'. Done this many times in Fla year around. Energy management system works great.
