Jerry_B's avatar
Jerry_B
Monroe Part no. for a shock absorber, 8K Dexter
I have a 2006 Mobile Suites with a 8K Dexter axle. The shock mount weld to the frame was bad and the mount broke off. I need to replace the shock. Anyone have a Monroe replacement part number? As a side note, when the shock mount broke, it cut the trailer brake wiring.
  • I did a little research on trailer shocks. The way the shocks are mounted way off vertical, I doubt the shock is doing anything worth while. I'm going to leave the shock off and see if anything changes.
  • Jerry B wrote:
    newman fulltimer wrote:
    So do you need just the shock or the mount and chock?
    Monroe shock is 555001
    Thanks. All I need is the shock. I had to cut it off because the lower nut was frozen tight. The upper bracket is still attached to the shock. All I need is a new shock and someone to weld the upper bracket back onto the frame. Sure wish I had a welder. Thanks for the part number. I'll order one from O'Reilles tomorrow.
    Cheaper on amazon
