JIMNLIN
Feb 10, 2017Explorer III
I would shy from any '03 and up 6.0 or 6.4 Ford engines. Check out Ford diesel forums for problems/out of pocket expenses some owners have had with these two engines. There are reasons Ford quickly dropped them both.
You don't need a DRW for that size trailer however the newer gen one ton SRW truck are better suited for 3500+ lb payloads in the bed.
Only you can decide if a one ton DRW will fit in your daily driver scenario.
I have both trucks and no way my crew cab long bed DRW will physically fit where I go in the big city or some job sites or in pastures.
Ram has several 3500 SRW trucks with 12000-12300 gvwr and 7000 rawr packages good for around 3800 lb in the bed.
If you choose the F350 SRW these can come with a 10000 gvwr or the same truck in a 11200 gvwr. Choose carefully.
The 3500 SRW GM will do anything Ford or Ram can do. The newer gen SRW trucks are all good trucks.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
