yep that is what I was thinking as well ,I do not think you would have this issue if you were towing that 42ft High Country with a 1 ton long bed Dually
goducks10 wrote:
How many miles on the truck? Maybe so new stiffer better rebounding shocks are in order.
JMO but part of the problem is it's a light weight 5th thats 42' long. My guess is that you're getting some flex here and there thats transferring to the 5th hitch. That coupled with a shorter lighter weight truck is going to give you the tug'o'war thing. Even if it's stiff enough, 42' is a lot of length and weight thats working against your shorter wheel base truck.
