Coach-man
Jul 31, 2016Explorer
I have a GD Solitude and love it, however I will tell you to base your selection on the floor plan that suites your needs! You stated you are full timers, so you should know what you need to make it work, even little things come into play. Your enjoyment of the rig over the next "several" years will be greatly enhanced if you do not have to compromise! Take your time, jot down the things you have thought about having while you were camping in your present rig. Then look at the 3 that you have narrowed it down to, and see which ones fit most/all your wishes! You will then be comfortable with your choice! Good luck!
OBTW, Grand Design's Customer service is second to none, just saying!
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
