2012Oudoorsman's avatar
Mar 05, 2020
MOR Ryde X Factor Frame Strengthening
I have a 2018 Open Range 374BHS. This unit has the Equaflex equalizers and correct track spring hangers. Within the last 3 years I easily have 10k miles probably closer to 15k miles as the unit just came back from the factor for 2 sidewall replacements. I'm not full timer but do take it out quite regularly from April to Nov, as much as the North East weather allows.
I am looking to add the MorRyde Xfactors to all 3 spring hangers. I would be installing these in conjunction with a MorRyde heavy duty shackle and wet bolt kit. Planning on reusing my current equaflex equalizers. I'm also thinking of just using angle iron and welding into place, much cheaper but not removable and probably voids frame warranty. Anyone have issues with self install supports?
These new kits would work if I decided to upgrade to the SRE 4000 later on but I'm not disappointed in the current equaflex so leaving this as is saves me about $400. I have 4 new Saliun tires but they are not currently installed. Has anyone had any issues with the spring hangers after installing the xfactor? I've seen a few failures on the Open Range page so I'm trying to catch this prior one. Brakes and bearings will be addressed during install. Anything else to consider?
  • Sure ashamed that Lippert cannot build a frame with sufficient bracing in the first place.
    Ken
  • The Correct Track extensions add more stress on the hangers so the cross bracing is needed even more.
    I built my own custom cross bracing that is bolted in to allow servicing things in the belly.
  • I'm not sure that the Xfactor brace will work with Correct Track brackets installed.
  • I had cross tubes installed on our 2005 Cardinal. It towed super after the addition per Lippert's instuctions.
    Should not be a warranty issue as Lippert supports the addition. Chris
