4x4ord
Nov 04, 2017Explorer III
Motorcycle on 5ver.
Anybody tried carrying an 800 lb motorcycle on the back of their 5ver? How did it work? I am wanting to build a hydraulic lift for mine
4x4ord wrote:
I found an online beam design calculator that allows me to put various beam dimensions in and calculate the beam deflection when weight is hung from the end. I was surprised at how strong the frame is of this Citation trailer. Hanging 500 lbs off one frame rail cantilevered 13 feet beyond its support (the rear spring hanger) would only cause .11" of vertical deflection. In contrast a 2" x 15" x 1/4" rectangular tube would deflect about 15% more. I think I'm going to mount a motorcycle lift on this trailer. If I notice any negative handling or bowing of the frame as a result I will add a third axle.
