Ray-EOD
Jul 15, 2015Explorer
Mounting a TV
I want to mount a 32 in TV over the walk through exit door in the garage of a Torque 380. This will be mounted on the inside of the outer wall. I have found the metal studs in the wall where I want to mount the TV and cut a 32 x 26 board to mount the TV mounting brackets to. My question is; what is the best screws\bolts to use to mount the board to the wall with? I know that the screws\bolts cannot be over 1 1/2 inch and they have to be metal to go into the studs, but what can I use to be sure the TV stays on the wall, while moving\towing and not damage the RV structure?
Thanks for any help you may offer.
Ray
Ray
