Dayle1
Sep 04, 2016Explorer II
One reason why it is popping up may be misalignment, meaning the seam is not directly over a rafter so the original staples had nothing to grab and new screws may need to be driven in at an angle. If the rafters are aluminum, they are probably just 1" wide, so not much tolerance for error. Also possible alignment is spot on but installer missed the mark or was out of staples. In any case, use screws not nails and 1" length should be fine, but 1-1/4" or 1-1/2" would be ok as well.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
