Traveler_II
Jan 23, 2014Explorer
If you’re moving soon it’s really cold out there. RV anti-freeze or the “pink stuff” they say is good to -50, but at 0 degrees it will start to turn slushy, doesn’t’ freeze solid. Besides doing what the other post has suggested look for some low point drain valve and drain any water out of them, before you use the pick stuff. Sometimes using the winterizing kit by the water pump can be problematic especially if this is your first time. Another thing you can do is drain all the water and put about 3 gallons of the pink stuff directly into the water tank and pump through all the lines. Just make sure you flush out your water tank before you use it.
P.S. there is some cheaper pink stuff good for -30, get the better brand.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
