Sgeorge's avatar
Sgeorge
Moving from a bumper pull to a fifth wheel ?'s
I asked this question in the tow vehicles section, but thought I would ask here. So I am looking for some advice, hopefully from people who have done the same thing. Here are the truck details, 2016 Ford F250, 4X4, SBCC, 6.2, 4.30. I am currently towing a trailer with a max weight of 6,000lbs; I am looking at moving up to a fifth wheel that will max out at 9,000lbs. I am happy with how the truck pulls the current trailer, but concerned that I might not like the heavier fifth wheel. I am not worried about pin weight and issues like that; the truck can more than handle the weights. The question I have is how much will I feel the increased weight in actual pulling. Will the truck slow down significantly? Will the 3,000lbs increase cause a large difference in pulling hills? Also what will moving from a bumper pull to a fifth wheel effect pulling in head winds, concerned about wind resistance. Thanks for any help you might give.
  • If and thats a BIG if the fiver actually scales out loaded around 9000 pounds, that means you will be dumping around 2,000 pounds on top of the rear axle. That is in addition to the 150 to 300 additional pounds for a hitch. Simple answer is does your truck have enough load carrying capacity to do that?
    I'd be really surprised if a 2016 F250 was even close to the rear axle capacity with that weight.
    LOL
    Especially a gasser...
    Lyle
  • Please do not double post. See the replies to your questions here. This thread is closed.
