74vette
May 04, 2013Explorer
Moving pin box on Komfort 5th wheel.
I have a Komfort 5th wheel with a Lipport pin box. The box is currently mounted in the lowest position on the pin box frame. I would like to move the pin box up one notch to reduce the distance between the trailer and the bed rail and level the trailer. The problem is that by moving the pin box up one notch, the pin box will hit the fiberglass shroud that goes around the box. There area I am talking about is a square hole cut in the fiberglass to allow the pin box to attach to the frame. There are several adjustment holes available but any movement up allows the pin box to hit the fiberglass suround in the front.. Is is possible to cut out the suround to give access for the pin box?
Thanks,
Thanks,
