TRIPLE8
Jul 16, 2013Explorer
Moving to LT'S
After having 2 Maxxis tires with tread separation I will be moving on to Lt's. I'm thinking of going with 235/85/16 E Bfg's Commercial Lt's. Since I added the 3rd axle I can afford the almost 500 lb d...
KATOOM wrote:Hi, the problems started before I added the 3rd axle. I just recently added the 3rd axle so the 4 tires were likely overloaded. Thanks
Interesting, because based on your weight numbers, you were far from overloading six of those E rated tires. :h
