Francesca Knowles wrote:
Automotive (stranded) wire. If space is limited, a spool of plain white 10 gauge should work for almost any application. (White can be roughly "color coded" with a felt pen etc. if desired.)
Also:
Utility knife with spare blades
Water pressure regulator
Power adapter(s) for stepping down cord from 50 amp end to 30/15 amp hookups. (Sometimes encountered at Public parks)
Thank you, I don't count the water regulator or adapters they are up there with water hose and sewer hoses, things you can't leave home with.
