jmtandem
Dec 03, 2014Explorer II
Chances are that if it pulls really bad, the hitch is adjusted to tight. If you had a 1960's station wagon, then you must put weight on the front axle, and that is when the WD systems where developed, for CARS! A truck, especially a F-250 or F-350 that can handle the 1,000 pound hitch weight uses a WD system, it does not need to be very tight at all. The front axle starts out with well over 3,500 pounds on it, and is likely to not pop up in the air (like a CAR). The rear axle only has about 3,000 pounds on it, and the ride will benefit from the extra weight
X 2
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
