shum02
Dec 03, 2014Explorer
jmtandem wrote:Chances are that if it pulls really bad, the hitch is adjusted to tight. If you had a 1960's station wagon, then you must put weight on the front axle, and that is when the WD systems where developed, for CARS! A truck, especially a F-250 or F-350 that can handle the 1,000 pound hitch weight uses a WD system, it does not need to be very tight at all. The front axle starts out with well over 3,500 pounds on it, and is likely to not pop up in the air (like a CAR). The rear axle only has about 3,000 pounds on it, and the ride will benefit from the extra weight
X 2
x3
I have my WDH on the minimum setting of the bars - 4 links on my Easi-lift with 900lb bars. It is almost pointless on 250/3500 series truck to fight the front springs pushing weight forward from a very unloaded rear axle. I have 900lbs of tongue weight with my KZ and had very weird handling until I quit treating the F350 like my F150 which need a LOT of front compression to move some weight forward off the rear axle. Once I backed off trying to move weight forward everything fell together on handling and ride.
Don't fight the truck.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
