howardwheeler
Oct 03, 2018Explorer
We were prepared to add plates to the opposite side, but when I cut a hole under the bed to get to that spot we discovered why it didn’t break. It has, in the exact spot where the other side broke, a full 2x6 beam welded perpendicular to the beam that goes to the pin box. It showed no signs of a break and was welded solid all around. And Larry is correct; this is an in house Western RV frame, noted for strength. This was the weak link in the whole structure and I guess after 15 years of bumps it finally gave out.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
