mikeof6's avatar
mikeof6
mystery wire on 2006 Weekend Warrior FS2600
On the cross member of the tongue behind the batteries is a 4x4 metal electrical box with a wire coming from the battery, connecting to what looks like a black squareish 1 inch resistor, then exiting the other side of the box and going under the trailer to somewhere. Does anyone know what circuit this wire might be used for. The connection on the resistor? looks a little rusty/corroded and I am wondering if I should replace it.
I'll be selling the trailer and I want to get things attended to.
Thanks in advance,
Mike
I stand for the national anthem!
  • If you are inclined to replace the junk self-resetting fuse/breaker I recommend either Bussmann Hi-Amp breaker or a Maxi-Fuse holder with #6 wire. Need the amp rating from the breaker to match same rating.
