laknox wrote:
agesilaus wrote:
kirbybear wrote:
agesilaus   Do you have a repeater on your TST system?
Repeater? It has a control unit with an LCD that shows the pressure and temperature on one tire at a time. It takes it several minutes to cycle thru all four tires and even more time if you have sensors on the truck tires too.
Repeater = "signal booster" if the base unit has a hard time "seeing" the trailer sensors due to distance.
Lyle
Distance hasn't been a problem, it does have an external antenna but it can see the fiver sensors as is.
