agesilaus wrote:
laknox wrote:
agesilaus wrote:
kirbybear wrote:
agesilaus Do you have a repeater on your TST system?
Repeater? It has a control unit with an LCD that shows the pressure and temperature on one tire at a time. It takes it several minutes to cycle thru all four tires and even more time if you have sensors on the truck tires too.
Repeater = "signal booster" if the base unit has a hard time "seeing" the trailer sensors due to distance.
Lyle
Distance hasn't been a problem, it does have an external antenna but it can see the fiver sensors as is.
OK. Just making sure that you knew that this was something that some applications need to use, either because of distance or because of interference. Frankly, I'm a bit of a tech-head, and have always thought it would be neat to have 2 cameras and IR sensors in each wheel well to =see= what's going on in real time. :-)
Lyle
