laknox
Oct 13, 2016Nomad
mrnoyb wrote:
I'm trying to decide which GM HD2500 body combination is best to pull a new 5th wheel. Crew or Double Cab - Standard or Long Box?
I'm looking at a Jayco Eagle HT 26.5RLS which is well within the capabilities of any new GM 3/4 ton pickup.
Please share your thoughts. I appreciate any advice you may offer.
Thank you.
I have an '02 D'max, CC, SWB, 4x4 and a very square-front FW. I can NOT hit my cab at full lock, right or left, when going forward. ALL will hit in reverse, and I have done so. A LWB or a slider hitch just gives you a little more room before you WILL hit. I do not know how a 2WD version of my truck, or a newer truck, will compare, but I've never felt the need for a LWB or a slider. Also, my B&W Companion is set as far forward as I can get it and I can open my tailgate while hitched, though can't get between it and my FW. I'm also looking at an Eagle HT and have no plans on changing either truck or hitch if I do buy one.
FWIW, I agree with the others, and you should at least consider a 3500 for "down the road". I sure wish I had back in '04, when I got my truck.
Lyle
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
