Two UTV's will need a 20' trailer. Mine uses torsion axles which allow each wheel to move independently of the others. The trailer will weigh 3000 lbs empty, so think about getting 5K+ lb axles instead of the cheaper models with 3.5k lb axles. I wanted mine to have a low break over angle when I carry cars plus was looking for something that would hug the road, so mine has 4" drop at the torsion. If you plan to drag the trailer around off road you may want to look at taller clearance setups typically used for sleds where the inside deck sits over the wheels with no wheel wells protruding inside. If you want to carry a car inside your trailer, plan on climbing out the car's window if you do not have a mid door in the side wall allowing you to open the car door.
