RustyJC
Dec 21, 2016Explorer
Sam Spade wrote:RustyJC wrote:
With a cold inflation pressure of 80 PSIG, I'd start with max pressure = 95 PSIG,
I agree with setting the pressure loss alarm at -10.
But if you set the increase alarm as above, or at any pressure really, what does it MEAN if you go over that.....and what will you do about it ??
Same thing for temp. increase......unless maybe only ONE tire consistently gets a LOT hotter than all the others, but you don't need an alarm to see that.
I set my TPMS system up on the pressure side based around the normal operating profile for my tires. On a cold morning, inflation pressure might be slightly under the cold inflation pressure when I last inflated the tires. After 3 hours on the Interstate on a hot day, I've seen pressures of 142-143 PSIG on our Goodyear G114s after starting out at 120 PSIG. Therefore, I'll set my high pressure alarm around 147 PSIG - if any tire has more pressure buildup than normal or than the other tires, I want to know it so that I can stop and check it out.
The 158 degF alarm setting on temperature is FAR outside the normal operating range of my tires, but according to TST that's their factory setting and recommended setting based on the advice of tire engineers who stated that degradation leading up to failure can occur at temperatures above that level.
If you don't want to know about high pressure or temperature, then set those alarm points as high as they will go.
Rusty
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
