ken_burke
Jan 17, 2017Explorer
WackAway wrote:
I just got a Carchet TPMS System for my 5'r which has max/min alarms for pressure and a max temp alarm. What would be good settings for these alarms given a load rating E tire? Baseline pressure is 80 psi cold (70 degrees). The sensors screw onto the stems, so I do realize the temperature readings probably are not close to inside tire temps.
Max Pressure = ?
Min Pressure = ?
Max Temperature = ?
Thanks in advance
My tire monitor used to make alarms. So I finally gave in and read the instruction. Have your wife read the instructions.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
