Hi, We're looking for our first RV and have come across a used truck/5th combo at a local dealer that is selling on consignment. The 5th is a 2008 Jayco 27.5rks that appears in very good shape inside...
Thanks for all the replies, The truck is a F150 4X4 supercab with the Triton 5.4 and tow package, 3.55 rear end. Ford's tow guide states a tow limit of 9700 lbs and a 10 to 25% pin weight. So if I read this correctly it should be fairly well matched. The Jayco has a dry pin weight of 1300 lbs and a gross of 8750 lbs. Do I have this correct?
