Mile High wrote:
Bamaman1 wrote:
Surge brakes work better for boats, as they're mechanical. Water and electrics don't work so well together. And a 19' boat needs brakes and tandem axles.
You're a braver man than me. I'd never consider double towing, and many states prohibit it for a reason. I'd rather rent space in a storage lot for either the boat or the RV close to where I usually camped.
A 19 ft boat could be a fishing boat with a 25 hp outboard, which may not need either! Weight is the criteria, not length.
Only saltwater is an issue for electrics because of corrosion. For freshwater electric is fine and far superior to surge, especially for mountain driving. Surge brakes overheat descending long passes. Converted mine to electric several years ago.
Some (many) brake controllers support additional axles. Just run new 10 gauge all the way back to the truck from the boat, dont tap the RV trailer brakes or you will have too much voltage drop through the factory RV brake wires.
The brakes on my dad's 20' Reinell trailer don't overheat when going down a grade. Surge brakes, in good working order, =should= have some sort of device that puts some back-pressure on the cylinder to keep this from happening. If it didn't, you couldn't even back up. We had an old water-wagon with surge brakes that =didn't= have this feature and had to make a U-shaped collar to slip into the slide to be able to back the trailer up since any movement backwards would lock up the brakes.
Lyle
