eDUBz
Aug 13, 2016Explorer
Need help asap in AZ
I'm in Winona she'll station off of I 40 I my tire flew off who do I call? My phone is 805-512-5811 if anybody here is from flagstaff and can help me out in contacts thanks.
eDUBz wrote:Blackdiamond wrote:eDUBz wrote:nayther wrote:yup. Lost the wheel and drum.
So did you lose a wheel bearing? I assume that's what caused the failure.
So, what really happened, the axle nut came off, right??
Did the bad bearing cause play/stress on the cotter pin and nut causing the cotter pin to fail and then the nut backed off? Did the axle get ruined? If it didn't, why not?
No, the axle nut and cotter pin were still there. The bearing failed and everything just came off. I got super lucky no other damage was done.
