Brisk
Jan 20, 2017Explorer II
otrfun wrote:aza2010 wrote:There is no easy way to answer your question. There is a significant amount of controversy in terms of what is safe, what is legal, in terms of payload capability and ratings for the Ram 2500 (or any of the Big 3 3/4-ton trucks). You're going to hear every imaginable suggestion: buy a bigger truck, buy a smaller toy hauler, put airbags on your Ram 2500 and call it a day, or not-to-worry, you'll be just fine as-is.
ok gents so I went ahead and used a calculator online to find out my max hitch weight rating for a fifth wheel hitch for my truck. Not sure if its correct so maybe someone can throw in their experience.
The answer I got was 3,825 or 3,060 with a 20 percent safety margin.
Here are the stats of the truck. I know the Gross weight may not be Actual weight.
Max trailer weight rating- 17,210
GCWR 25,300
GVWR- 10,000
Rear GAWR 6,500
Am I in the ball park here or is that calculator not right?
It's not an easy task, but somehow, you're going to have to establish your own comfort level in the midst of all this controversy.
I'll start this off by saying your truck's payload is your biggest hurdle or handicap. Your truck's payload is documented on the sticker located inside your truck's door jam. If I had to guess your truck's payload, based on the limited information you've provided, it's roughly 2,200 lbs. for a 4x4, higher for a 4x2. Once you establish your payload, then you'll need to decide whether you're going to work with this "artificially" low payload number (based on your truck's 10k GVWR) or a higher payload capability based on your truck's 6,500 lb. RAWR (assuming 18-20 in. OEM wheels).
I know, you're probably thinking, 'what is he talking about?!' Yup, the controversy starts rights here. You can write a small book on this stuff. For now, I'll step back and let others chime in with their thoughts and views. All you can do is take it one step at a time, consider the pros and cons, then make your decision.
Good luck!
I agree 100%. Your truck is capable beyond its payload and GVWR but at the end of the day the GVWR is the legal number.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
