mcguirehg's avatar
mcguirehg
Need help replacing window link arm
My windows link arm has separated from the window frame. I purchased new link arms for the window. However, I can't seem to find the correct connecting hardware to reattach the link arm to the window frame. It looks like a ribbit that is suppose to attach the link to the frame with a slight opening so the window with open and close...this is not a slider window, but one that onens up and down by turning the knob. This window is on a 2007 Montana 342pht. Any help would be appreciated
  • I have been searching online and called in a mobile rv tech with no luck. I was hopeful I could find some help on the forum, but have not had luck.
  • edbehnke wrote:
    you can always go to the fall Montana rally in Goshen, and Montana will probably replace it. Montana works well with repairs like this.
    That would work but the rally is over now. We had planned on attending but had to cancel due to a medical issue.
    One of our window arms (awning type window) broke off on a rear escape window. Dealers can't seem to get the correct replacement. We were going to get it replaced at the rally.
    Now I guess we will just keep waiting until the dealers can get the part.
  • http://www.kinrowindows.net/page2.html
    I purchased the RS07014 LINK ARM on the attached link. I have the correct part, but can't find the correct part to the attach the link arm to the window frame. It appears to be a special type of rivet. Thoughts?
  • you can always go to the fall Montana rally in Goshen, and Montana will probably replace it. Montana works well with repairs like this.
