sncurtis's avatar
sncurtis
Need Help with Small Toy Hauler Purchase
I apologize if this is a dumb question, I'm pretty new to the TT world and am very confused.
My husband and I were planning on purchasing a 2015 Skyline Aljo 160B toy hauler that is new but on closeout at a dealership so seems to be a good deal. Our tow vehicle is a 2008 Toyota 4Runner V6 with a 5K tow capacity and we have 2 dirt bikes at about 250 lbs each. When I first contacted the dealership about the trailer they said the unloaded vehicle weight was 2,300 lbs and the GVWR is 3,850 lbs which equals 1,550 carrying capacity.
However, after doing some more research I saw that on their website they actual list the weight as 2,965 lbs and similar units online have had a weight closer to that as well. I emailed the dealer about the listed weight and she insisted that the 2,300 lbs, not 2,965 lbs, was correct and it does in fact have a 1,550 carrying capacity. Am I wrong to think I'm being lied to here? We live in the middle of nowhere Wyoming and this dealer is about 400 miles away so we can't just stop by.
If the weight is actually 2,965 lbs with 3,850 lb GVWR that would only leave 885 lbs left for cargo and with our bikes being about 500 lbs total, that would mean my husband, dog and myself couldn't all be in the trailer at once with the bikes? That seems odd...
What am I missing here?
Thank you in advance!
  • All new trailers have a yellow sticker with the actual weight (uvw) as it left the factory, usually found on the screen door or in a cupboard. These weights can vary quite a bit from brochure numbers. Don't take the dealers word. Have them take a picture of the actual sticker for the specific tt and email to you.
    On a side note, you're going to need to upgrade the receiver on your 4Runner. The stock one is only bolted to the cross member and is not rated, or strong enough, for use with a weight distributing hitch (which you will need with that tt). You'll want the one that bolts to the frame. It came on most V8 4Runners and the Lexus 470. Curt also makes a really nice aftermarket one. They are easy to install. Hardest part is accessing the bolts to get the old one off.
  • What are you missing........
    GVWR is about max weight trailer can weigh while being towed......
    Stationary/parked with stabilizers down you can throw a party and invite ALL your friends :B
    The UVW (Unloaded Vehicle Weight) or 'dry' weight c=maybe listed as 2300#
    The CCC (Cargo Carrying Capacity) may be 1,550#
    BUT you have to subtract the weight of:
    Full Propane cylinder 4.5 gal----20#
    Fresh water capacity (full tank and Water Heater)17/6---23 gal/193#
    Any Optional times that may have been added----????
