mprice11's avatar
mprice11
Need new tow vehicle
I recently upgraded fifth wheels from a 1993 Jayco eagle to a 2005 285BHS Coachman Chaparral Bunkhouse. I know I need a larger truck to pull this as it's UVW is 7771 and it's GVRW is 9450lbs. I want to stick to gas as it will be used to pull on the weekends, generally a half hour away, sometimes 3 hours away. Does anyone pull a fifth wheel of this weight with a 2500HD with 4.1 gears? If so, how does it pull and what is the general fuel mileage? The truck will be a crew cab with standard box. Does the 6.0 gas have enough torque or do I need to look at a V10 Ford?
  • I think you will be fine. Check on the truck's tow and haul ratings.
    BTW I don't know exactly when ford dropped the V 10 in the F 350 and below. Maybe around 2011.
    the ford 6.2 pulls my fifth wheel fine for me.
  • I had an 2003 2500HD 6.0, 4.1 crew cab 4x4. I used to pull a Keystone sprinter 303BH. Dry weight 7570. GVWR of around 9500 can't remember exactly. The only issue I had was in South Dakota. My temperature gage would climb. Truck never really over heated. I traded off shortly after that and went with the one in my signature. The 2003 was actually raged for towing 10500. With GVWR of 9200 for truck.
    Good luck.
  • Look at the Cargo Capacity of the truck. If it can CARRY 2500lbs +/- then you will be ok. A larger cargo capacity on your rear axles is always better for a 5er truck.
    I think you will be fine with any 250/2500 truck and a 5er with a GVWR of under 10,000lbs but that is just a generality not a for sure.
    Without knowing the cargo capacity/rear axle weight rating of the truck and the hitch weight of the 5er you cannot get an exact answer.
    You should get around 9=10MPG and my 2500 diesel pulls my 10,000lb fiver like it is not there...at least until we hit a steep hill and it downshift. ;)
